[Bio] / Babel / bin / build_md52id_for_uniprot2go.pl Repository:
Log of /Babel/bin/build_md52id_for_uniprot2go.pl
Links to mgrast_dev_03052011: (view) (download) (as text) (annotate)
Tue Dec 1 15:22:43 2009 UTC (10 years, 7 months ago) by wilke
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2
initial babel checkin
