[Bio] / Babel / bin / DB_Schema_Postgress.sql Repository:
Log of /Babel/bin/DB_Schema_Postgress.sql
Links to mgrast_dev_08112011: (view) (download) (annotate)
Thu Sep 2 15:51:36 2010 UTC (9 years, 10 months ago) by tharriso
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012
Changes since 1.3: +9 -10 lines
new organism table column names
Tue Aug 31 18:32:51 2010 UTC (9 years, 10 months ago) by wilke
Changes since 1.2: +8 -2 lines
Wed Jul 21 18:49:40 2010 UTC (9 years, 11 months ago) by tharriso
Changes since 1.1: +91 -70 lines
same updated schema as for mysql, modified commands to work better with postgresql
Thu Jul 15 20:28:39 2010 UTC (10 years ago) by wilke
